The picture above shows my flexible PLA print in comparison to my original data file. As you can see the corner radius of the 3D print is approx 0.8mm rather than the 0.2mm suggested. I have pasted my Cura settings. (The printer is a recent factory built machine in conjunction with Cura 13.06.4.) Does anyone have any ideas how to improve the quality of the print - which is a decal project?
Cheers,
gr5 2,189
Do you have a photo? The default UM extruder nozzle size is .4mm diameter so I would expect corners to have a radius of at least .2mm. Are you seeing more than that? If so try more cooling maybe? Or printing slower and fan on 100%. Perhaps 20mm/sec.
