Hide Cura printer bed visually
LeoY
Posted · Hide Cura printer bed visually
Is there an option to hide the printerbed temporary in Cura (3.5). The reason is when the bottom-part of the printobject is checked, it is not very well visible due to the printerbed drawn in Cura.
Also when using the custom support-addon, or custom support blocker-addon at the bottom area of the printobject, then the same issue occurs (bad visibility of the printobject).
Leo
    /optimistic mode on
    The left side where also the button is for the custom support (blocker) would be great :)
    Maybe when more people use the mentioned addon's (or different ones), then the neccesity of such feature will be more noticable.
    Thanks for your fast reply.
    Leo
    • 1 year later...
