Massive extrusion jumps and errors midway through gcode, BUG??
Posted
· Massive extrusion jumps and errors midway through gcode, BUG??
I think I found the issue for the record if anyone experiences this again:
I tried different versions of cura:
It seemed to be an issue with the how the model was made. If there is some excessive amount of internal geometry, then the slicer cannot interpret the model properly and I guess this is just the symptom. The best indicator of when this was the problem is if the supports generate through the model unexpectedly or even show up in a layer that is not the "active layer". What I mean by that is if you were to scroll through layer view you would see a support at layer (say 359) pop up at Z height 0.1. For me, I had some bosses and hole cutouts that had excessive geometry line between the boundaries. However, the symptom may affect a completely different location than where the bad geometry is located.
FRjhracing 0
