I don't see nothing wrong in cura and if I rotate the object I always get the same result.
I got same result with my object and also with a lot of thingiverse object.
I'm thinking that maybe it could be the head bearing on the Y axis... maybe.. I really don't know.
About speed, I print at these speeds:
Infill: 28
Wall:28
Outer Wall:19
Inner Wall: 28
Top/bottom:28
You think I'm too fast?
Acceleration and jerk as default.
Thanks.
Smithy 1,145
I see very similar results on some objects, not all and hardly depending on the shape of the object. First I also thought it is a backlash, but it wasn't. Then I tried a different slicer and also different printer and got everywhere the same result. So I guess there is something wrong with the source file. You can check it in layer view of Cura if you see something strange there, but I don't think you will see much there.
What helped was to print slower.
