Have you installed the CC Red Core as well and are you using an S5? Otherwise you get the warning because the material is abrasive and would wear it out normal nozzle and feeder if you try it on the UM3.
I am currently using the normal version of Zytel 3D1000FL, which is supported on UM3 and it is my primary printer. So I guess, I can't use the ones I mentioned above on UM3.
Also I am running into a problem with 3D1000FL, the normal one. The printer stopped working and gave the following error. I looked up online and changed the printcore. the same thing happened again.
- 10 months later...
Having some dimensional accuracy issues with the stock profile..
Could also use having it updated to support material station.
PranavB 0
I bought two variations of this filament: Zytel 3D10C20FL BK544 and Zytel 3D12G30FL BK309. One is carbon fiber filled and the other is glass filled. I could install their profiles on Cura, but when I select them, it shows it's not supported. Can you look into that?
Thanks!
