Dupont - Zytel 3D1000FL
SandervG
Posted · Dupont - Zytel 3D1000FL
Dupont makes Zytel 3D1000FL available to Ultimaker users via our material alliance in Cura.
You can access all available materials via Cura > Marketplace > Materials.
Are you curious about others experiences using Zytel 3D1000FL or do you have any other questions regarding this filament? Feel free to post them below.
Some links you might find useful:
Technical Data Sheet
Safety Data Sheet
Printing Guidelines
    • 9 months later...
    I bought two variations of this filament: Zytel 3D10C20FL BK544 and Zytel 3D12G30FL BK309. One is carbon fiber filled and the other is glass filled. I could install their profiles on Cura, but when I select them, it shows it's not supported. Can you look into that?
    Thanks!
    Have you installed the CC Red Core as well and are you using an S5? Otherwise you get the warning because the material is abrasive and would wear it out normal nozzle and feeder if you try it on the UM3.
    I am currently using the normal version of Zytel 3D1000FL, which is supported on UM3 and it is my primary printer. So I guess, I can't use the ones I mentioned above on UM3.
    Also I am running into a problem with 3D1000FL, the normal one. The printer stopped working and gave the following error. I looked up online and changed the printcore. the same thing happened again.
    20190910_114244.thumb.jpg.8908b938af315956c16475a9a8d87fba.jpg20190910_114238.thumb.jpg.a2c61279ab0836955c089733f586119e.jpg
