Make sure "travel optimization" is turned off. I think when this is on it will ignore "infill before walls". I could be wrong. But it won't help your print much. You have severe overhangs. You need some kind of support. You can design support columns into the design of the print or if you have a printer that does two filaments you could use dissolvable support.
This is an extremely hard print for a 3d printer without dissolvable support.
1
Rublie14 0
Can anyone help me?
