@Carla_Birch thanks for the info. i installed the plugin. but after changing steps per millimeter for x and y even from 50 -> 45 the size is still the same.
what am i doing wrong here?
Thank you very much.
I wouldn't recommend to alter the Esteps. Since we work with a bowden tube I can imagine that the effects may not be immediately visible, and may even last longer than after your first layer and I think you don't want to add under extrusion to your print, right? If you have elephant feet I would first suggest to reduce initial horizontal expansion if your model allows it. Perhaps set it to -0,5mm
Regarding other optimizations, can you try to adjust your profile accordingly:
Line width:
Make the line width equal to the nozzle diameter
Speed settings:
Equalise all print speed settings (i.e. infill, outer wall, inner wall, top/bottom) (good starting point would be 40mm/s)
Jerk settings:
Set all jerk settings (infill, outer wall, inner wall, top/bottom) to 20 mm/s
Good luck!
zungara 10
Keep in mind that the first layer will normally extruded with more material at default with Cura. For me mostly I reduce the percent value from 120% to 105% So I do not need to change any E-Steps to reduce elephant foot
