3D Model Not Showing Up In CURA
ike
Posted · 3D Model Not Showing Up In CURA
Hi All. I am trying to 3D print a model using CURA. I made the model in OnShape, and then downloaded it into an STL file. In all other 3D modeling programs the model shows up, but in CURA it just doesn't show up, and then says that it will print nothing. I will link my model below. Thanks!
Part Studio 1 - Part 1 (1)_fixed.stl
    You have a problem with the scaling. I imported your STL in Cura and got very very small point in the middle of my build plate. After scaling to 1000% the object has now 18x18mm so it is too small in the unscaled STL.
    • 3 months later...
    I had the same problem for a completely different reason.  I designed a project on TurboCad 19, which defaults to inch dimenensions.  Cura could not see it until I converted to millimeters.  It took me a while to figure this out.  It seems like it would be extremely simple for Cura to recognize the units mismatch and convert, but no.
    STL files don't specify units.  Which is a problem with the STL specification.  So there isn't an easy way for Cura to notice.
    However if the model is too large to fit by say 1000X then cura automatically shrinks it down so you can at least see the model.
    It would be nice if the model is < 1.5mm that it would pop up a message or something to see if you want to scale it up.
        • 24 replies
