If you dont put your own M104 S0 M140 S0 right after the G28, cura will will insert them at 1st layer temps.
You will need to put the M104 M140 later in the start codes else cura will not heat the bed/extruder.
Edited by obewan
Edited by obewan
thanks guys,
i got it working with this and seems to be working as i need it to.
code taken from all over
G28 ; home all axes
G29 ; Auto Bed Level
G28 ; home all axes
M104 S{material_print_temperature} ;Start heating extruder
M140 S{material_bed_temp_wait} ;Start heating bed
M109 S{material_print_temperature} ;Wait for extruder to reach temp before proceeding
M190 S{material_bed_temp_wait} ;Wait for bed to reach temp before proceeding
M117 Purge Extruder ; Shows "Purge Extruder" on the screen
G92 E0 ; reset extruder
G1 Z1.0 F3000 ; move z up to prevent scratching of surface
G1 X0.1 Y20 Z0.3 F5000.0 ; move to start-line position
G1 X0.1 Y180.0 Z0.3 F1500.0 E15 ; draw 1st line
G1 X0.4 Y180.0 Z0.3 F5000.0 ; move to side a little
G1 X0.4 Y20 Z0.3 F1500.0 E30 ; draw 2nd line
G1 E27 F5000 ; retract filament 5mm
M117 Done Purging Extruder ; Shows "Done Purging Extruder" on the screen
G1 Z1.0 F3000 ; move z up little to prevent scratching of surface
M117 Now Printing... ; Shows "Now Printing" on the screen
I can't make this code work on an S5 with 4.3.0, no matter what the start GCODE says, apparently the firmware is inserting the bed and nozzle heating commands as well as the leveling command prior to the start up GCODE. I want to use Geckotek EZstick hot as a printing surface however, am experiencing the same problems noted in other posts with the hot nozzles boring holes in the materials and the prints failing with nozzle probes. Is there some way to start cold with an auto bed level and then heat the bed and nozzles? I tried changing the z offset but the holes still get bored. Thanks.
Seems like the placeholder names have all changed again .
http://files.fieldofview.com/cura/Replacement_Patterns.html
try something like
M104 S{default_material_print_temperature} ;heat nozzle to default temp set in material settings
M140 S{default_material_bed_temperature} ;Start heating bed
M190 S{material_bed_temperature_layer_0} ;Wait for bed to reach temp before proceeding
M109 S{material_print_temperature_layer_0} ;Wait for extruder to reach temp before proceeding
Thanks for the thought. Unfortunately, it doesn't work. Tried with the G28 and G29 commands inbetween the first two, and preceding the first two. Printer still brings print head to the front center and begins heating the bed. Frustrated. Any other suggestions most welcome.
On 10/29/2019 at 12:46 AM, Geep said:I can't make this code work on an S5 with 4.3.0, no matter what the start GCODE says, apparently the firmware is inserting the bed and nozzle heating commands as well as the leveling command prior to the start up GCODE.
There you have your answer...
On the S5 the start procedure is build into the firmware. You can't disable or change it with gcode.
Therefore you can't use those "soft" printing surfaces on the S5. Adhesion sheets from Ultimaker can be used, PEI sheets too, but nothing that can not withstand the nozzle heat.
Has anyone found a solution for the Wham Bam in combination with the S5? I'm experiencing the same problem, generating the "nozzle offset probe failed" error.
I seem to have solved the "nozzle offset probe failed" error by increasing the spring tension on the build platform. The springs are now almost completely compressed and the prints no longer fail during auto bed levelling.
Smithy 1,145
The settings page should be the same on Windows and MacOS and I can remember that there was a thread some days ago about this topic. So check the search function if you find the thread.
Besides that, I personally don't think it is a good idea to manipulate the start sequence, because there is a reason why Ultimaker heats up the extruder before the auto leveling. I think I have read that the nozzle needs to be heated that the measurement is accurate enough.
