Thank you!
I can post a picture of a grinded filament but I think you know how it looks like. When the grinded material gets half the plastic tube the feeder can't manage to feed the filament anymore due to friction.
Yes, the pre-sliced files works perfect, no grinding at all just some dots in the filament from the feeder. I notice that the pre-sliced files do retract the filament quite often but when I print with Cura there's no retraction. Could this be the problem?
I'm using Cura 3.6 and the printer is 3 days old :)
Smithy 1,090
Hi and welcome!
Can you post a picture what you mean? And which Cura version are you using?
You should not need "special" profiles, Cura works great out of the box with the UM 2+
What do you mean with, it works great from SD card? You mean when you print the pre-sliced files from that card?
