Hmm? not really at the moment, but I guess you are right, the printer will heat up but nothing happens and then the firmware throws an error. So check again the head. Maybe a contact problem between the head and the cores? But unusually that this would happen with both cores.
1
kmanstudios 1,120
Just to rule out the print cable, have you tried to push it back in as well as make sure it stays seated during printing?
I found that some of my print cable issues got take care of when I did the following:
1. Seated the cable firmly in the printhead.
2. The print cable is held by the retainer clips on the bowden tube. So I make sure I push the cable down into the hole and then push the clips down closely to the printhead. As the print is performed, and the clips are far a way, it can produce a wiggle in the cable that will eventually cause the lead in the cable to siggle loose.
It is just a suggestion. In this, it is all I got, but I hope worth a try.
Smithy 1,135
Check also if the front fan is running. The fan could be blocked by some filament strings or other plastics and if the fan is not running, which cools down the upper part of the hot end, you can also get an error.
DF-Werkzeugservice 9
Thanks for the answers.
I've checked the cable, it's pushed in finde. Also the fan isn't blocked at all.
I forgot to mention before:
The cores don't start heating at all. They remain at ambient temparature (the sensor says so and I also physically checked with a thermometer)for a little time and then the error message appears (I suppose because of there's something like a runtime error in the firmware when the temperature dosn't change).
Any other suggestions?
