Z Distance Issues, Soluble Supports
AbeFM
Posted (edited) · Z Distance Issues, Soluble Supports
This is not the first time I've had this issue - I thought I've posted it before but can't find it.
Can someone tell me how to get my supports to print on the object instead of floating in free air?
Edit: This is not the first time I brought this  up. CAN SOMEONE PLEASE COMMENT? I'm over a month into this problem and I would really appreciate some guidance.
Edited by AbeFM
    Posted · Z Distance Issues, Soluble Supports
    Note that I tried this with Z overirdes x/y and the other way around, even with "minimum support distance" set to a small or 0 value, I get the same behavior.
    With all distances set to 0 you get support that touches but lose the ability to keep vertical supports off  your part.
    Does anyone else have a copy of the CURA software?
    If you do, could you slice something with dual materials and the contact distance set to 0 and let me know if you see that gap or not?
        • 24 replies
          • Heart
