tinkergnome 926
6 hours ago, Shirly said:The problem is, since it happened the door of the print head won't close
Perhaps it's just the metal bracket that is bent a bit, it's explained here:
https://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#front-cover
edit: and here - https://fbrc8.zendesk.com/hc/en-us/articles/115001519726-Why-Won-t-My-Fan-Bracket-Close-UM3-UM3X-
Edited by tinkergnome
neo-ninja 1
Two ways to solve this.
1.) shut the door and push it down towards the print bed to bend the door arms slightly (they have bent out of shape) Use a little pressure but not alot.
2.) Print a door hook, there is one on thingiverse. It basically holds the door shut. I have to use this one one of my UM3s as the door keeps popping open.
