tinkergnome 927
1 hour ago, Smithy said:You can also try a more recent version of Cura, 3.2. is also quite old.
Lulzbot maintains its own Cura edition with it's own version numbers, it's a separate thingy:
Ohh, understand, thanks for clarifying.
Wouldn’t it make much more sense to ask Lulzbot for support then? The Lulzbot Edition has diverged quite a bit from Ultimaker Cura, so chances are your issue is specific to their changes.
Smithy 1,144
Filament material diameter is correct? 1.75 vs 2.85
