Thanks, I'll take a look there. I am surely not the first or only one that needs this feature. It would be a nice addition and I can't believe it would be that hard to code.
Tom
Tom
UM, just looked under "Experimental" and nothing about bridging is there. I'll keep looking but I saw no bridging controls anywhere and I am in Expert mode.
Tom
Apart from the fan control for bridges as mentioned above, it's also possible to override the fan for skin layers that are above support. This is good for PETG as you can crank the fan up to 100% when printing a skin above support and this makes it easier to separate the support from the skin.
I can assure you that those bridging settings have been in Cura for at least a few versions (arrived with 3.3, perhaps?)
Forget "expert" mode, do "show all settings".
Or just enter "bridge" in the search field above.
I figured "Expert" mode would show everything. Surprise... it doesn't. Cura sure has odd terminology.
But thanks, the bridging stuff is, indeed, there.
Tom
7 hours ago, T_om said:I figured "Expert" mode would show everything. Surprise... it doesn't. Cura sure has odd terminology.
LOL, you would need "guru mode" to see everything!
Smithy 1,145
This is not possible in Cura as in S3D. You cannot specify the layer to switch on/off the fans.
But, there is an experimental setting in Cura "Bridge Settings" where you can define a lot of settings for bridging and also the fan speed. So you could switch off fans completely and set it higher for bridging.
