Hi Ahoeben, thanks for getting back onto me on NY's Day! I have an UM3 at home and I want to be able to monitor and cancel prints if needed from work or just away from the house. I didn't intend to slice via the OctoPrint, but I was looking forward to being able to run timelapses of the prints. I can access the interface of Cura Connect while on the home network, but how do I do this when offsite?
The UM camera viewpoint isn't ideal for determining if a print is succeeding in reality, so I have a babycam sitting on to of my perspex housing for a plan view that I can log into on an app, but it is only to view.
I am currently logging into TeamViewer on my home PC to, from an app, then open Cura to cancel a print if necessary, but my PC needs to be on. I was hoping that by using OctoPrint, I could manage all of this.
ahoeben 1,963
Though it is theoretically possible to connect OctoPrint to the serial port of the controller board of the UM3 (modifying the hardware), it would be a LOT of software work to get it working well.
The UM3 has its own (raspberry pi alike) little linux computer, with software that is has a functional overlap with the OctoPrint software. That software also handles switching cores, calibrating core xy offsets, material management and more that is unique to the UM3. Connecting OctoPrint would bypass that software, so you would have to somehow handle that in OctPrint.
What would you like to acomplish with OctoPrint that you cannot do with Cura Connect?
