T-Glase fooling around
PaulK
Posted · T-Glase fooling around
My daughter (6) gets to pick filament for some things, so I get to figure out how to print them 🙂 This time it was T-Glase. Interesting material. The printing recommendations, including from Taulman, are all over the map and  conflict like crazy, so finding a starting point was tough. This benchy is a basic "normal" profile and not perfect by any means; more importantly, not optimized for clarity. I think I'll want to try popping in a 0.8 core and printing big thick layers as they recommend to get high clarity too. Got a few LED projects in mind that might work well and would please her.
Prints real slow, but the top surfaces (not very visible here) are amazing and glassy.
    Recently someone on this forum mentioned these links, about printing transparent models. Was that you @kmanstudios? I don't remember who.
    https://hackaday.com/2018/12/11/true-transparent-parts-from-a-desktop-3d-printer/?fbclid=IwAR3uP3W0fAE_ej6bp8VvflOeXPvFEv7yyHoH-jEt8jJBPWlaoNjq9E33tVg
    http://fenneclabs.net/index.php/2018/12/09/3d-printing-transparent-parts-using-fdm-fff-printer/
    Contrary to popular recommendations, they used *thin* layers (plus slow and hot printing) to get good transparency.
    Might be worth experimenting with both unusually thin and thick layers, and comparing the results?
    Personally, when printing PET, I never got better than a "frosted glass" look. But printing very slow at 100% infill definitely improved results, even at lower temperatures, so the material has enough time to flow into all corners.
        • 24 replies
