Hi Gr5,
Sorry, I didn't but I'd tagged the UM3. I've the black ones, so it might be just bad luck. I've gone around the whole unit tightening everything and have another print on at the moment and it looks good - so far. I was in touch with my re-seller and the slider block plastic parts are only a euro plus VAT and delivery, so I'm going to order 4 with the belts. I'd prefer to be looking at them instead of for them, when they do need to be replaced. It's a pain, but I feel relieved to know that they are consumables and do wear out. I was more concerned that it shouldn't be happening or a known problem.
gr5 1,967
You didn't say what kind of printer this is.
Is this a UM3 with white blocks? If so then this is a known problem and contact your reseller and they will send you free replacements. Or contact igo3d. The white blocks crack. UM switched to black blocks that work much better over a year ago.
