I think I've found your problem. The STL file looks OK. The problem comes from the model having thin walls, so thin that CURA don't print the walls thinner than the orifice or line width. You would have to use a 0,25mm print core to get the model to improve printing but even at 0,25mm it will not be perfect. You can also turn the "Print thin wall" option on in "Shell" settings.
Is this model design to be 3D printed?
Good luck!
Thank you for your reply.
18 hours ago, Framar said:Is this model design to be 3D printed?
Yes, it is.
Framar 24
Can you proide the STL file? It might be the 3D model having bad surfaces...
