Idea for Rotate Setting
Samrobmoe
Posted · Idea for Rotate Setting
Hi, I work at a University and use CURA myself at home.
I have found that a lot of people seem to have a bit of difficulty with the rotate tool as it can sometimes be a bit of a pain rotating the object with the circular grab system, I'm not sure if anyone else finds this?
I have also used Makerbot Desktop quite a lot and within that, there is an option to specify what angle and which plane you wish to rotate the object in within a text box and with the option to select 90 degree intervals.
Is this something that could be integrated into CURA?
Apologies if this is posted in the wrong place, I couldn't find an ideas thread.
7 minutes ago, Smithy said:
No, without pressing Shift it rotates by 15° and with pressing Shift you rotate by 1°.
It does just the opposite if you have snap rotation unchecked. Still not as good as a box to enter the rotation amount.
