I reprinted the part using Ultimaker White Tought PLA and while the part is looking better it still shows some under extrusion. I did tuned the print by reducing print speed and increasing the plastic flow on the S5 in the middle of the print but the print is barely acceptable. I think that this is mainly caused by starting to print after retraction. Is there a setting that can be used to prime the nozzle after retraction?
So far printing with 0,8mm print core results in 100% rejected part...
Smithy 756
You layer bonding is very bad, so I guess you print too cold and/or too fast. Slow down your print speed (try 30 or 40mm/sec), and try increasing the print temperature 5-10° C. Because you are printing with the 0.8 print core you need more flow, and if you now also print too fast, you have to adjust your print temperature that the nozzle can melt the material faster.
Additionally, keep your environment temperature warm. Even if you have the glass doors, if the room is too cold, the cold air gets also inside the printer and could cause such issues. You can also try to cover the top of the printer with a big towel or something like that.
