Cannot "ack/force" third-party material (Cura 4.0)
Yes. Known bug. This exact issue has been reported to Ultimaker but I'm not sure if it's on their list of things to fix. Hopefully/probably it is.
OK thanks (you are as reactive as usual!!)
I was unable to spot it in github so I had filed https://github.com/Ultimaker/Cura/issues/5251
You may want to close it as well then
Note that though @gr5 is a gr8 moderator here, he has no such power on the github queue. Only you or Cura developers can close your issue on the github issue queue.
Edited by ahoeben13 hours ago, ahoeben said:Only you or Cura developers can close your issue on the github issue queue.
1
OK, I leave it to Ghostkeeper who seems to be involved -- at least it looks like I did not posted a redundant entry on github.
jeremie 13
The corresponding global setting is posted as a feature request here https://github.com/Ultimaker/Cura/issues/5250
