Doesn't ChangeZ alter the feedrate factor instead of the "speed" itself? So it affects all the "speed" with a ratio.
Could you look at if the output gcode has M220 in it?
If there is, please check if your firmware has M220 support.
On 2/17/2019 at 8:58 AM, alexjx said:On 2/16/2019 at 9:19 AM, gr5 said:First of all realize that there is a minimum layer time feature. I think it defaults maybe to 5 seconds per layer so that may be restricting the speed. You can turn that feature off. This keeps the quality up because it looks all melty if you don't let the previous layer cool a little.
Cura has gotten complicated. There are about 8 printing speeds. I would try a few things:
1) Try setting most of them to 0. In the old cura (15.X.X) if you set the speed to 0 it would just not set the speed at all.
2) Open the gcode file in a text editor. It's quite easy to look at. Look for "F" commands. Those set the speed in mm/minute (60X larger than mm/sec). Note that anytime it does a non printing move it has to change the speed. Note that anytime it does a retraction it has to change the speed (extruder speed is different from XY axis speed). So you may have to disable all retractions and set the non-printing moves to speed 0 or to the same speed as the printing speed? Not sure. Hopefully in vase mode there are none of these.
Thanks for taking the time to reply. I did have min layer time turned to 0. I did check the F commands and all layers were the same. No retractions since printing in vase mode.
QuoteOn 2/17/2019 at 8:58 AM, alexjx said:Doesn't ChangeZ alter the feedrate factor instead of the "speed" itself? So it affects all the "speed" with a ratio.
You are correct. Firmware is Repetier 1.0x which I believe does have M220 support. I did try printing the square tower using manual feedrate control on the printer itself which worked but I learned that the printer doesn't like to take corners at a high speed (they show significant degradation beyond 40mm/s) so for this test I think I need to switch to a cylinder tower.
Still would like to know how to do this automatically if anyone has any other input. Much thanks!
Edited by Zbyszko
gr5 1,873
