I checked the filament diameter (was set to 1.75mm, i adjusted it to my measured diameter of 1.72mm), and tried another print, but it didn't make much of a difference. Unless there is another location to change the diameter? I'm changing it under Preferences->Materials->Properties->Diameter.
I also slowed the skin from 27.5 mm/s to 15 mm/s, and there isn't much difference either. I can print these items with Kisslicer at the same print speeds, and I don't have the same issue.
Here is the project file for the above image:
Edited by jrjones
burtoogle 505
Hello @jrjones, looking at your pictures, the skin looks slightly under-extruded so I wonder whether your extruder calibration is correct and that the filament diameter is constant (and correct). If those things are correct, have you tried printing the skin a little slower?
