yellowshark 153
Well no not strictly true. I have never use initial layer line width, maybe my version of Cura does not offer that, but I run my initial layer at 70% flow and that reduces extrusion
burtoogle 509
Hello @nobio8. Yes, they have very similar effect in that they both scale the amount of filament extruded. One small difference is that changing the initial layer line width alters the number of lines used to print the brim but changing the initial layer flow does not.
A further difference is that changing the initial layer line width actually alters the positions of the printed lines but changing the flow doesn't, it just makes the lines fatter. Compare these two images...
nobio8 2
than you smartavionics,
so it behaves as expected, so one could combine two of them in
certain scenarios
