Some of those holes/slots *might* be from pva although usually they are rounder. A piece of pva can be fall onto your print and then when it tries to print the next layer it fills in around the pva which later dissolves away leaving a hole.
However this print probably doesn't need any support. The single flat roof that I assume is over the entrance - that is worth supporting but not 100% necessary. But the quality for that will be much better with PVA. I would remove PVA support everywhere else (there are several ways to remove support e.g. setting the angle, but probably the best is to use the tool on the left side where you click areas to remove support then stretch the cuboids to cover everything but where you want support).
Smithy 1,134
Hard to say, but yes could be from the PVA. I don't think it is under extrusion, because then you would have much more holes or issues.
You can avoid those scratches when you set Combing to "not in skin", this should help for the surface quality.
You can access the webcam directly from a browser: http://<your IP>:8080/?action=stream
And welcome aboard! 🙂
