Model get empty part after slicing where 2 meshes intersect
BenRQ
Posted · Model get empty part after slicing where 2 meshes intersect
I tried to modify an existing mesh by adding a simple rectangle box, that intersect with the model and fill some empty parts for 5mm.
The model looks good in Fusion 360 and in Cura.
Only when I slice it I see that some part are missing.
What did I do wrong ?
Is there a way to fix this in Cura or Fusion 360?
Please note I also have the same problem with a cylinder on this model: you can see the hole on the left side of the model.
I tried all "Mesh fixes" option without success.
Ben
    I always thought that this alternating was the desired behaviour? When the slicer encounters the first edge it turns the material on. At the second edge = material off. Third edge = on, fourth edge = off, etc...?
    Otherwise I think it has no way to know whether it has to fill a model or not, since the STL-file only consists of triangles, if I understood that well? Maybe software-engineers like smartavionics or ahoeben could shine a light on this?
    Anyway, I use this feature to make hollow text and watermarks inside a model. I design the watermark separately, outside of the model, and then I just move it inside the model. After export to STL it is automatically sliced correctly, thus Cura automatically hollows-out the text.
    Like here in this example, where I have copyright notices, a ruler, and some decorations as watermarks inside the model, a keychain. Or in the transparent testblock below. (For reference: text caps height = 3.5mm; text legs are 0.5mm.)
    Thanks for the answer and the example @geert_2, it makes sense now that you say it.
    But I'm surprised this is not an option to setup somewhere and even more why this would be the default option.
    I mean you can just cut the intersection out of the model in your editor, I don't see why this would managed in the slicer.
    I tried this Union overlapping volumes ( https://ultimaker.com/en/resources/20424-mesh-fixes ), but it does not change the behaviour for me.
    I'm a beginner, so I may miss something obvious here but for me it would make more sense to edit the model in the 3D editor.
    I found what was causing the issue.
    I'm using a support blocker on one part of the model, to slow down the print speed on this specific part.
    If I remove this support blocker, it works fine: no more empty part !
    It seems like using a support blocker inhibit the " Union overlapping volumes" features. This may be a bug.
    I'm using 4.0.0-BETA-2
    This support blocker does not touch the part with the issue, and I changed only the print speed.
