yellowshark 153
Well imho if your glass is bowed it aint flat and no amount of levelling will make it flat - maybe you can fiddle and make a portiion of it flat big enough to get the job done. The distance between the glass and the nozzle is greater at the edges than in the centre (with your bowing) and that is why your back left will be working fairly well because the distance is greater and clearly closer to what is optimum for your print. From what you say then you virtually transparent areas will be in the middle where the glass is more compressed against the nozzle. i.e. shorter distance.
It all figures apart from your bent glass!
gr5 2,333
So I would consider maybe turning autolevel off so that you get 100% consistent results.
The glass is not as flat as you need. Even if it was, the plate beneath it can easily bend it by 0.5mm from one end to the other. So you would have to flatten the system, not just the glass. UM uses tempered glass - I believe only because it's safer if it does break. But tempered glass isn't as flat because of the way it is made. You can put tiny shims such as washers under the glass and adjust them until you get it flat enough. That is probably the path I would take (shims and tempered glass) combined with disabling autolevel, combined with only using a portion of the bed (tempered glass tends to be thicker in the middle so possibly printing around the edges).
Most prints only need leveling to an accuracy of around 0.2mm or 0.1mm. So I suspect autolevel has an accuracy of around 0.1mm or possibly even 0.05mm. Which is of course much to course for you.
