UM2: Feeder backlashes (skips backwards)
mowijo
Posted (edited) · UM2: Feeder backlashes (skips backwards)
With my Ultimaker 2 I see this:
Problem
  • My feeder backlashes at a frequency of roughly 1Hz. This leaves gaps in my prints because filament pressure on the nozzle disappears for a quarter of a second or so every time.
    See this video
  • It happens with all my kind filaments: PETG, PLA and ABS
  • The malfunction started out of nowhere. I had finished a print and was about to start the next. Then the backlashing began. Perhaps I changed filament, but I dont remember.
What I have tried
  • I have cleared the bowden tube. It is easy for me to push filament through the removed bowden tube without force.
  • I have cleared the nozzle using the atomic method.
Help
Does anybody know what I can do to ensure a steady flow of filament. Preferably by fixing the backlashing.
Best regards,
   Morten
Edited by mowijo
    Posted · UM2: Feeder backlashes (skips backwards)
    First please don't use the word "backlash".  That has a specific meaning.  A synonym to backlash is "play". It means something is loose and when it switches direction, nothing happens initially.  Like 30 years ago I had a car where there was 1cm of backlash in the steering wheel - when I would pass through from right to left there was a moment where the steering wheel stopped turning the wheels and you could feel it took less force for a moment.
    Anyway you can call this "feeder clicking" or "feeder skipping back" or "feeder skipping".  It's very common with the original UM2 and was "fixed" with the UM2+.
    Anyway to the problem - when you are doing move material like this it is common for certain filaments so this may be normal.  More likely I'm thinking this material is ABS.  I have a spool of ABS this exact color.  Or this could just be normal.  did you try printing with it?  If you are getting feeder skipping on the first layer that might be normal but if you get any on the second layer then it's a serious problem and very fixable.  Let me know and I can send you the list of underextrusion causes but my first guess is this material is not PLA.
    • gr5 changed the title to UM2: Feeder backlashes (skips backwards)
    13 hours ago, gr5 said:
    First please don't use the word "backlash".  That has a specific meaning. ...
    Thank you for clarifying that. I will use the term feeder skipping, then.
    The material in the video is indeed not PLA. It is PETG and I have had lots of successful prints with that very filament until the feeder out of nowhere started skipping.
    However, the skipping happens on all my filaments: Official Ultimaker PLA, no-name ABS and no-name PETG.
    A list of possible causes would be very welcome.
    Thank you a lot for your reply and your effort,
        Morten
