"Infill Before Walls" in Cura
Fortunato
Posted · "Infill Before Walls" in Cura
Hi everyone,
I'm trying to activate the above setting in Cura, but there's no way !!!!
I have already tried all the combinations requested in the info of the activation setting in the appropriate window (Infill Density, Wall Extruder and Infill Extruder).
Does anyone know how to tell me the real combination to make this setting appear ????
    On the three horizontal bars next to your search window you click "manage setting visibility" search for the infill before walls an make shure its marked then it should appear in your infill list 🙂
    Did this ever get resolved? I am having the same problem. No matter what I do the setting doesnt show. (enable visibility in settings, change related settings, but it still tells me its hidden because of the other settings. I have other profiles with the same exact settings, and it shows in those projects, but for some reason in some projects it gets turned off a,d no idea how to get it to show again.
