@tonycstech - you can certainly see retractions in layer view. As you can see here - make sure you check the box "show travels".
Light blue are retraction moves. Dark blue are non-retracting moves. Both types are non-extruding moves. If you look carefully there are about 30 non-retracting moves below and 2 retracting moves.
burtoogle 509
Hello @tonycstech, I agree that the layer view could be more useful. The last time they revamped it, I suggest that they make it more like the craftware viewer which is what I use when I want to inspect the cura gcode. However, most people don't need that level of details so I can see why they didn't bother to enhance it further.
What retraction problem are you referring to?
