If it saves to UFP by default on an ender, that's a bug. Could you report that on github?
I'm a noob as well, and using Cura 4.5. Up till now, the default to the SD card was gcode, but I used an extension script to be able to print a temperature tower, and now ever since, the default to the SD card is a utf extension. There is no pull down for the SD drive.
burtoogle 509
Set the file type to gcode in the drop-down menu?
