UltiMaker uses functional, analytical and tracking cookies. Tracking cookies enhance your experience on our website and may also collect your personal data outside of Ultimaker websites. If you agree with the use of tracking cookies, click âI agree, continue browsingâ. You can withdraw your consent at any time. If you do not consent with the use of tracking cookies, click âRefuseâ. You can find more information about cookies on our Privacy and Cookie Policy page.
Solved. I removed the Z-rod and put those 4 into the Trapezoidal Nut ... it was easier than I thought, because the nut has a round inlet that locks into place ... I just twisted it to align the holes.
Â
I just started a new print and ER06 did not show up any more.
Â
I hope it helps someone because I haven't found any information about it in the UM forum.
Â
Â
So whatâs new?
The obvious change is the S7âs height. It now includes an integrated Air Manager. This filters the exhaust air of every print and also improves build temperature stability. To further enclose the build chamber the S7 only has one magnetically latched door.
Â
The build stack has also been completely redesigned. A PEI-coated flexible steel build plate makes a big difference to productivity. Not only do you not need tools to pop a printed part off. But we also donât recommend using or adhesion structures for UltiMaker materials (except PC, because...itâs PC). Along with that, 4 pins and 25 magnets make it easy to replace the flex plate perfectly â even with one hand.
Â
Â
Â
Reliable bed tilt compensation (no more thumbscrews) 2.4 and 5 GHz Wi-Fi A 1080p camera (mounted higher for a better view) Compatibility with 280+ Marketplace materials Compatibility with S5 project files (no reslicing needed) And a whole lot more Â
Weâre hosting a free tech demo on February 7.
Â
We generated a special version of Cura 5.2 called 5.3.0 Alpha + Xmas. The only changes we introduced compared to UltiMaker Cura 5.2.1 are those which are needed for the new supports. So keep in mind, this is not a sneak peek for Cura 5.3 (there are some really cool new features coming up) but a spotlight release highlighting this new version of tree supports. Â
Â
Ultimaker S5 Pro Bundle, Ultimaker S5, Ultimaker S3 Ultimaker 2+ Connect. Â
They're ready for you on the Ultimaker Academy platform. All you need to do to gain access is to register your product to gain free access.Â
fergazz 60
Â
Â
