Posted · Ultimaker S5 stops after leveling
When I send a job from Cura or try the Print head xy calibration and the printer completes the leveling and then the head just goes home and sits in the corner.  I have let this go for hours. I have also reset the printer to factory setting and reloaded the material.
What am I missing?
    Not really on setting this completely right.
    I did start to use a newer USB drive as well as did a switching callibration.
    While it did improve greatly, it is not completely gone away. But, instead of several times a day, it has only done that once since I mnade those adjustments.
    So I ran the Switch Calibration and it seems to try to print the the XY calibration. Though nozzle 1 seems partially clogged so I will be running the nozzle cleaning when I get a chance.
