Hi, GR5! The printer is a Chinese Zonestar printer, essentially a stainless steel frame Prusa design. Software is (I believe) Marlin, running on a Melzi board. Here's a link: https://www.aliexpress.com/item/Upgraded-Quality-High-Precision-Reprap-Prusa-i3-3d-Printer-DIY-kit-with-2-Rolls-Filament-free/32342171432.html
This link shows the current model; mine is about 2 years old, and has the older Melzi board.
The strange thing is, it worked fine for quite a while, and has only started to print backwards in the last 6 months or so. (I don't use it a lot.) So, in the beginning, it did work well, which leads me to believe that I've inadvertently set a switch to the wrong setting. I can't imagine a hardware failure causing this.
BTW, the reversed print printed properly. So, somewhere in the slicer or the printer, a horizontal mirror image is being asked for and created. I just have no clue how this might have happened. Thanks for your help! >Charlie
gr5 2,192
What kind of printer is it?
Cura expects 0,0 to be in the front left corner. If either your Y or your X axis is backwards then it will print a mirror image.
