Hello,
Are the G0's the only difference between the two flavors
If it's the case, try to do a PostProcessing Plug in to change all the G0's in G1 ?
In case I can do it if you want
Hello,
Thanks a lot, @smartavionics, I tried one of the recent release from you and it works! The output is now in Mach 3.
Thanks, @JCD. We are postprocessing the output files...yes, that's the only change needed right now.
Thank you again.
Hi @smsusi, looking at the Cura source code, the only effect that selecting Mach3 flavour is that the extruders are named A, B, C, etc. rather than E.
Happy that smartavionics already did the trick 👍
Thanks again, I will try this too.
burtoogle 508
Hi @smsusi. Until recently, there was a regression in Cura whereby the mach3 option was being ignored (which you have found!) A fix has been submitted to the Cura devs and I should think that it will be in the 4.1 release. In the meantime, if you are using either Linux or Windows (sorry, not OS X), you can try one of my releases that already incorporate the fix. I don't know how well the Mach3 flavour works as I don't think it sees a lot of attention so when you get to try it out, if you find any issues, please report them.
You can find my releases at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
They do not conflict with the Ultimaker releases.
