You can check if the direct URL is working: http://<your_ip>:8080/?action=stream
If not, you can try to reset "Cura Connect" from the printer menu, which helps often to get the live stream back. (Personally, I have to reset Cura Connect every few days, then the cam is working again - but unfortunately only for a few days)
1
nallath 1,080
If it's only showing a single image, that's a bug! Could you report it on github?
