Ultimaker 2+ .. adding time to prints and then fails
Posted
· Ultimaker 2+ .. adding time to prints and then fails
Sounds like 2 different issues.
1) The "time left" is wrong. This is common - usually it takes almost exactly the time that cura says it will take. But part way through the print it may think it will take much longer if the initial layers were more filament and the future layers are less. Even 10X as the upper layers may need 1/10th as much plastic. This issue is not normally a serious problem.
2) Air printing. What you describe sounds like underextrusion (or not extruding at all) but a photo would help. Anyway the UM2+ is notorious for underextruding due to the teflon part getting old. They are cheap and need replacing every few hundred hours of printing. Some will last only 200 hours, some will last 500 hours. They are cheaper than filament and are set to be at a good price because UM is nice and they know you will have to change that part often.
There are other possibilites but this is the most likely.
gr5 2,004
