Carla_Birch 114
My S5 prints fine and as been from day one, you got to keep in mind that the Cura settings are not a one fits all jobs, going by the model you will need to edit settings.
Looking at the model you got fine walls with cut outs, you will need to slow down the print speed to stop ghosting, also because the walls are thin you don't want a infill but you want to edit the settings so its just printing walls, because printing a infill will make a lot of vibration on walls that thin.
Also the part don't look that big so i don't know why your print times so long, was you printing with PLA and PVA support? If so you can greatly lower print time by using a mix of PLA support with just PVA Roof, saves a lot of time and PVA because looking at the images all support you can access so you don't need full PVA if you was using it.
Edited by Carla_Birch
SandervG 1,502
Hi @AAGC, thank you for your post. Have you already been in touch with your reseller regarding improving the print quality and level of satisfaction?
While in some cases maybe obvious, could you pinpoint which things you're not satisfied with concerning print quality?
