have a look here for 1.754 conversion..
http://www.3dprintingforum.us/viewtopic.php?t=265
https://thegr5store.com/store/index.php/um2-175.html
And yes I would just get an original meanwell power supply..
Thanks for the link for the conversion! Hopefully that will fix a lot of my headaches..
I went ahead and ordered a new power supply, so hopefully that will fix those issues as well.
I’m my personal experience the bootup of um2 boards usually are due a bad heater. It’s easy to debug, heat bed for X minutes (same as the time needed to reboot while printing). Then turn off. Then heat hotend for the same time (or more ofc). Then finally if doesn’t fail heat both hotend and bed for X minutes, if only then fails it might be the psu, otherwise is a heater block
I think I tried those steps before, and it lasted for 30 minutes or so before I got bored and tried to print something. Just to have it fail a few layers in. Maybe it was a combination of factors including me trying to print 1.75 without mods. I went ahead and ordered the PSU and it should be arriving either today or tomorrow, so I guess we'll see.
I wanted to update on this. I ordered the extra power supply, but it's just stayed in the box for now as I haven't seen a repeat of the problem. I swapped over to the 2.85mm filament that I have from when I bought the printer, and I've printed three or four 3 hour prints.
Now I'm looking into convincing my SO to allow me to tinker in the Mark2 upgrade 🙂
XYZDesignPro 69
Power supply brick on it's last legs and getting ready to fail? Just a thought. Before I purchased my UM3 I had a UM2. Not a 2+, had to replace the brick at one month old under warranty. Acted similarly.
Like I said, just a thought
ultiarjan 1,209
My gut feelings says that if a power issue causes the reboot there probably is no log...
About the firmware, I'm running tinkerware, but on mine you find the version in ADVANCED/PREFERENCES/VERSION, may be a bit different in the original firmware, not sure.
Can you borrow an UM2 power brick from someone to rule out it's the cause? (where are you located?)
The first thing I would do is check all connections on the main board, are all connectors ok, are the screws (depending on how old the machine is) for the bed heater tight?
And unrelated, but why do you set filament to 1.75, is the machine converted to 1.75 ?
anonomouscoder 2
Thanks for the advice, I was kind of afraid it might be a power supply issue. I still have the original power supply that came with the UM2. Should I try to get the same one, or is there a better alternative?
Most of my filament is 1.75mm PLA, Normally I can run it just fine, but I guess it just clogs a bit more. Setting it to 1.75 in the printer's settings seems to just make it push the plastic faster to compensate for the lower thickness. Are there other steps required to fully change it to 1.75?
