Problem with top off print
Timbe
Posted · Problem with top off print
2 hours ago, Timbe said:
Here is picures from cura and pictures from 3d model. Missing top "textures" Hope this help.
I sorry, but for me, the sliced model looks complete, nothing is missing in my opinion. If you just mean the texture, then this is a usual texture of a top layer in 3D printing.
    Posted (edited) · Problem with top off print
    If you try using the ironing function you may find that will improve the top surface for you. I have only tried it once and in parts of the model it was gobsmackingly good but in other parts it was poor. But I was using Cura 2.7 and I suspect it has been improved in later versions
    Edited by yellowshark
    Hey, thank you all for interesting in my problem. I try yellowshark method ironing function and that's what i'm look for. TNX!
    Hi @Timbe good to hear you have a satisfactory result. I guess you are using the latest version, or close to, of Cura. I must install ia later version and give it a try again !
