s I get the impression that for PLA you want an open design to aid cooling and for ABS a closed design to maintain
ABS is difficult to work with because it shrinks more than PLA. This sounds simple but causes many problems. PLA also shrinks but not as much. PLA45 doesn't shrink. One way to deal with shrinking is with a heated chamber so that the shrinking isn't occurring as much *while* you are printing but after you are done. A heated chamber helps both PLA and ABS but isn't really needed for ABS. An open chamber is helpful for being able to see what is going on and so that you can reach your hands in from more directions. But an open chamber is not necessary.
Also there is a patent regarding a heated chamber so even the UM2 comes without a front and top (you have to build your own).
The side panels on the UM2 appear that they might be easy to remove but I'm not sure.
So a heated chamber is not bad for PLA other than being able to stick your hands in more easily if it is open.
gr5 2,229
For UM1 and UM2, the feeder only takes 3mm filament. In fact 2.9mm is ideal as 3.1mm is too wide for most bowden tubes (the tube at the top of UM1 and UM2). The nozzle hole diameter is .4mm which is maybe a more important specification.
People have gotten 1.75mm to work in UM1 but it requires changing many parts. Some people have done it with stock UM (no changes) but it doesn't work very well.
3mm filament is easy to purchase and available at many places around the world and in many types of plastic (PLA, PLA45 PLA90 ABS, flexible PLA, much more).
