FYI for anyone looking for the answer to a similar problem - I contacted our support company and they suggested it was the back-left stepper motor belt that was loose. I tightened the belt as per the Ultimaker online manual and the noise has gone away.
geert_2 557
Did you clean and oil the X and Y rods, so they move very smoothly? More friction could also lead to more noise.
On one of my UM2, I once had a belt rubbing against the flange of a pulley, but that made a squeeking sound. After I carefully wiped the edge (only the edge!) of the belt with chemically inert silicone grease, the noise went away.
Don't use petroleum oils or grease on rubber, this may damage it. Only use inert lubricants. And don't get it on the teeth: it could make them slip.
