5 hours ago, gr5 said:That model has very little support so I'm not sure what the problem is.
I rarely use support generated by cura. Instead I just model the support I need directly in cad.
Cure shows exactly the support where you would exspect it by the red color.
take a look here - it's red too on the similar faces in the symmetry.
https://1drv.ms/u/s!Ap0XTBN0ykvEhKxUL19pBDPwmU53Cg
I tried to set up for this experimental TREE support system - WHAT this time it IS symmetric !
look here whatCuro generated:
https://1drv.ms/u/s!Ap0XTBN0ykvEhKxV8nyP3a2Q7sbr6g
The support is NOT touching the model and SOMETIMES it's NOT symmetric like the model and not ALL red faces are supported ... I don't get it !
Any ideas ?
gr5 2,192
