Dim3nsioneer 553
I would have said that an UM3/S5 starts with the support material in extruder 2 on the first layer...
My experience is the same as with @Smithy, but it probably depends on what material is selected for printing the brim or skirt.
Smithy 1,090
As far as I know you cannot select the order, but extruder 1 is used first if you use both materials on the same layer. The next layer should then start with extruder 2 to avoid a useless head switch.
