Cheers,
I have to use this firmware edition since nothing else seems to work on it. I tried all previous editions and i've bricked the machine before (fixed it though). I'm actually having trouble with a post processing script so I thought if I reinstalled the firmware it would fix the problem. I'll try a factory reset and see if that does anything.
gr5 2,330
Yeah it used to be here:
http://software.ultimaker.com/jedi/releases/
But not anymore. They hid it somewhere. Talk to your reseller. Threaten to return the printer until they tell you where to get the image file.
Note that you can't downgrade from 5.X to 3.7.6 unless you use the micro-sd-card unbricking procedure. Have you done that before? If not then maybe it's not worth the trouble.
