Does not hurt, they are communition errors, but they get corrected in the software.
How to resolve the problem?thanks.
Daid is saying they don't cause any problems. You can ignore them. Are you having another issue? Besides messages in the log?
It caused every layer prints at different positons that cannot successfully printed 3d projects.
Please show a photograph. It sounds like maybe your pulley set screws aren't tight enough.
It looks like there's a problem with your image. Maybe the site doesn't allow hotlinking?
To post an image, click on gallery in top left corner of this page, then after you have uploaded your picture(s), start a new posting and click on "my media" next to the smiley icon to insert any gallery picture.
Looks like hotlinking was the issue. Here's the image deago tried to post.
This looks like your pulleys are slipping. I'm not sure if it's X or Y axis - you should be able to tell that yourself.
Once you know which axis it is, each axis has 6 pulleys (SIX! not 4). 4 of the pulleys have the longer black belts on them. 2 of the pulleys have the short belt (to the motor). Make sure ALL 6 pulleys have had their tiny little set screw tightened. Tighten this screw quite a bit. It should be very tight. Consider also marking the pulleys with a permanent pen and also the rods so you can see which one is slipping.
Most likely it is one of the 2 pulleys on the short belt.
Daid 301
