Maybe I'll try kisslicer this weekend. Or an older version of Cura.
Recommend that you try Slic3r - worked for me.
May I ask WHERE exactly you people got version 13.10 ?
http://software.ultimaker.com/Cura_closed_beta/
Will be released soon, with some minor bugfixes.
Note that the butterfly model is quite horrible, with all the internal flat holes.
Sure is.
Very first time I've needed to use an alternative to Cura.
I just printed the butterfly but I used Cura 13.03. That's with the older slicing engine before steamEngine. It came out great. I was worried about the hinge but if anything it's a bit loose - so I guess I could print it smaller (I printed it at 1X).
Aah! Thanks for the tip.
I've printed several via Slic3r at 1x and then tried at 1.6x but that didn't slice properly,
Just tried at 1.6x with Cura 13.04 (which was already on my machine) and it turned out perfectly.
The hinge is loose. Those I printed at 1x with Slic3r the hinge was 'seized' and had to be gently 'unfrozen'.
Might try some smaller ones...
gr5 2,070
I was going to print that Monday but when I ran it through Cura and looked at layer view it had too many problems. One of the antenna wasn't going to print and part of the hinge doesn't start printing until the 3rd layer - in thin air. I turned on support but it didn't put any support under that in-the-air hinge. So I just decided not to bother. Maybe I'll try kisslicer this weekend. Or an older version of Cura.
I don't think Fix horrible is necessary in this case as I believe I did xray view and I believe there was no red. But I could be wrong.
