Mark 2 With Cura ver 4.1
Posted · Mark 2 With Cura ver 4.1
The printer definition is now included in the standard Cura installation (from Version 4.1 on).
If you have copied the json-files to the configuration folder in the past, you may want to clean this up and re-add the printer in Cura, but that's it. There are no manual steps necessary anymore.
  • 5 weeks later...
Ummmmmm...
With a fresh install of 4.2.1, the only reference I can find is Ultimaker Original Duel Extrusion...? Am I missing something? Do I still need to add any config/resource files or is the duel extrusion for the original the same for mark2?
Thanks
        • 27 replies
